Página 1 de 1
China Non-metallic Expansion Joint manufacturers
Publicado: 23 Sep 2019, 04:57
por sft1235
Rotating compensator is a new type of compensation,and no pressure thrust,the corrosion resistance compensator.compensation is by rotatuig drum and the conncction beween the pipes (virtual) rotary center on compensation for the pipeline ends of thermal expansion thrust of compensation.
With the aid of wide experience and expertise, AOGUANG is an ISO9001 certified company specialized in rotating compensator type a. As one of the leading manufacturers and suppliers in China, we warmly welcome you to get buy the quality and precise stainless steel hoses made in China from our factory.China Non-metallic Expansion Joint manufacturers
website:http://www.agbellow.com/compensator-series/non-metallic-compensator/
