Página 1 de 1
Black SiC Powder factory
Publicado: 16 Sep 2019, 04:01
por wry731
Chemical Composition
SiC: 98.5%
F.C: 0.15%
Fe2O3: 0.20%
Grit: F12-F220
Properties: Excellent hardness, High strength, Superior chemical inertness
Application: Grinding cast iron, Non-ferrous metal, Rock, Leather, Rubber, etc.
The hardness of abrasive grade silicon carbide is between fused alumina and synthetic diamond, and its mechanical intensity is higher than fused alumina. It is also friable, sharp, and has thermal and electrical conductivity to some extent. They are appropriate for working on cast-iron, non-ferrous metal, rock, leather, rubber, etc.
We can supply different grades of Black Silicon Carbide in the quantity of 3,000 tons per month.
Specification as following:
SiC: Min 98.5%
F.C: Max 0.15%
Fe2O3: Max 0.20%
Magnetic: Max 0.030%
Grit: F12-F220
Other specs can be supplied as clients’ request.
Inspection Equipment
Process Control
Company Honor
ContactBlack SiC Powder factory
website:http://www.cnsicah.com/silicon-carbide/black-sic-powder/
